TwinTurbo.NET: Nissan 300ZX forum - It's a good idea to pull the AC BOX lower cover and clean it
jzack
on January 09, 2016 at 4:56 PM
no i did not remove that, I noticed it's there but I figured
posted by YlwPrlZTT
on January 08, 2016 at 06:01 PM
out. Check to make the drain pipe is clear too. I found some mold due to moisture. I also sprayed the coils with a mold disinfectant - Lysol or similar.
Heater box removal help needed.
YlwPrlZTT
17:26:40 01/08/16
Did you remove the cabin to engine bay firewall gasket that
jzack
17:35:27 01/08/16
YlwPrlZTT
18:01:09 01/08/16
It's a good idea to pull the AC BOX lower cover and clean it -
jzack
16:56:26 01/09/16
So I got it out. Holy shi*! Next time i'll just buy a new Z
YlwPrlZTT
20:41:39 01/09/16
Yes, the job is a total PITA. Way more time consuming than
jzack
20:48:03 01/11/16
I didn't get all of them off, I left one on and I think
YlwPrlZTT
00:23:17 01/12/16
I also removed the blower completely, it had all sorts of
YlwPrlZTT
20:44:47 01/09/16
Is there any need to remove the a/c box or anything else or
YlwPrlZTT
18:03:02 01/08/16
The two boxes overlap quite a bit. It takes a fair amount...
Ted (92TT)
16:43:02 01/09/16
Here is another question. I removed the blend door motor
YlwPrlZTT
20:46:57 01/09/16
Should be ok (n/m)
Ted (92TT)
13:01:28 01/10/16
Well I tried it but there just seems to be too many things
YlwPrlZTT
16:50:01 01/10/16
